4l60e to th350 swap
That is their instruction sheet for most of the swap. The kit is for a 700 R4 which is 'physically' the same as the 4L60E. You WILL need to do some programming of the ECU to make everything work. If you call their tech line and talk with Terry Geter, he'll point you to the right people nearest to where you live.
Lots of luck. Looks like this is becoming a common swap!
Also, do a search 'cause there have been a number of posts about this swap in the last 4-6 months.
