RevMax
Not much at all actually a car with an efficient 3600 stall with 3.23's or 3.42 gears should keep up with traffic fine around 2200 rpms and will move as soon as you lift your foot off the brake. I have a 3600 fti sitting waiting to go in...
My car is on street tires some POS cheap *** tires that the old owner put on. They had 32 psi of air in them. My wife wont let me do DR's since it is her car.. I launched my car @ 1500 RPMs when I went the 13.6 and 2200 RPMs when I went 13.3.. I cut a 1.996 with the 13.6 and a 1.899 with the 13.3.. It was my first 2 times running a Automatic car @ the track let alone with a 3200 Stall converter.. I consider myself a Shitty driver.. I am sure with a Drag radial and a 1.7 60' My car will run 12's.. Not bad for a stock LT1 with an Airfoil and 3200 stall..
Oh and I am on stock tune with stock Gearing..
Now we just need more ppl to run your converter so we can see more results.
on bottle 1.53 60ft... so far.. now i cant get the car to hook..lol.. hopefully my new hoosiers will do the job with the new shot this winter, as its still 90 degrees at night here in AZ...
It's my daily driver and it works perfect I drive every day 70mph to work at 2k rpms the converter when flashed from a dig with street tires u can lay down 100 ft burnouts
