To Transgo or No
Thanks,
Mike
Thanks,
Mike
Yes! TransGo kits make the trans perform better and increase it's durability (they should hire me! lol). IF your tranny is in good shape, I'd invest in one ASAP. Get the PSK that Summit sells or the HD2 kit. Both are the same.
On top of quicker, firmer, and snappier shifts...the TransGo increases fluid flow to the 3-4 pack which is the biggest down fall of the stock 4L60E. I have ZERO Torque Management on my Z71 for close to 10K mi now and I've had the TransGo and billets for about 20K mi. Trans fluid comes out clean on the 10K interval changes.
Shoot me a PM and I'll get you the drill bit sizes due to the large stall. They are larger and I'm at school so no access to them currently.
You should just test the solenoids. They typically work or they don't. The TransGo will come with pretty much everything you need. Also get an aluminum 1-2 accumulator, new filter, new gasket, and that's all I can think of for now.
