how to pick a converter
Old Nov 17, 2011 | 07:13 PM
Bowlson's Avatar
Default how to pick a converter
is there some kind of formula that i can use to select the right converter
Old Nov 17, 2011 | 07:18 PM
Circle-D's Avatar
A lot of factors involved. Cam specs, toque curve, HP, gears, weight, tires.....And then intended usage comes into play. If you fill out or Ask Chris form, link in sig, I will help you select a match for your setup.
Chris
Old Nov 17, 2011 | 08:20 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Before I got my yank I emailed them and he wanted to know engine and modes rear gear and tire size. Can't wait to try my 3200 stall.
Best calling or emailing whoever you go with
Old Nov 17, 2011 | 11:18 PM
01ssreda4's Avatar
There is no reason to worry with all that. You call up the converter manufacturer and tell them all your info and they spec it out for you.
Old Nov 18, 2011 | 07:39 AM
Bowlson's Avatar
Thanks guys
Old Nov 18, 2011 | 07:52 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
As Chris stated ther is a lot that goes into proper converter selection. Call or cantact the manufacturer and see what they suggest. I will be more than happy to make a sugestion. Either go to our website www.fticonverters.com and fill out a spec sheet or simply give me a call at 1-866-726-8358 and I will help with your selection.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Nov 18, 2011 | 11:49 PM
FasTimeSS's Avatar
call greg at fti for a converter let him spec you a converter I have one of his for th400 ls1. I drive all the time on the street and it drives great. Greg is the man for converter
