no fluid pressure?
Old Nov 20, 2011 | 01:59 PM
6th gear's Avatar
Default no fluid pressure?
Im having a problem with my 4l60e. It wont go into gear. I can move the gear selector and you can everything in the transmission working. The dash also indicates witch gear you are in. So i was told it could be 3 problems 1 the internal wiring harness. 2 the front pump. 3 the torque converter is not making contact with the input shaft due to the flywheel being from a camaro. I was told to remove the lines off the transmission cooler and start the car and if nothing came out than my front pump was shot and i need to replace it. I was also told to see if the flex plates are different from the camaro and the gto even thow its the same engine and trans. The torque converter is bolted to the flywheel and the trans is against the engine. What could my problem be guys?
Old Nov 20, 2011 | 02:36 PM
6th gear's Avatar
If im spinning the flywheel and everything is hooked up should the back tires spin?
