SS3800...what gears?
Old Mar 13, 2004 | 02:35 AM
cobrakillerta's Avatar
Default SS3800...what gears?
Ok so i just bought a Yank SS3800 and also a Moser 12-Bolt which has 4.10's in it.
I'm 99.75897676% sure i will want to change the gears...but i'm undecided if i should go down to 3.73 or 3.42
My car will be all bolt-on...and doesn't see the track THAT much
I rather not lose alot of top-end either...but would liek to pull well on the highway when need be
Also...what kind of gears should i get...Strange, Richmond?
I want strength but not a ton of noise...but i figure w/ eitehr of these ratio's and an awesome installer that shouldn't be a problem
From what i see...Richmond seems to be the choice
So help me out :worship:
Old Mar 13, 2004 | 05:17 AM
98SS Blackattack's Avatar
I would give the 410's a shot since they are already installed.From there you will be able to figure out what to go to next. you may like them. I have no need for gears, even with nitto first gear is mostly tire spin on the street.
Old Mar 13, 2004 | 06:27 AM
boomcase's Avatar
If you dont race alot then Id go 342s Great gear for all purposes. I just installed a TCI 3800 and I run 342s and it is a great combo for a street and strip car, You will be happy. I dont think you will gain more than a tenth in the 1/4 between 373s and 342s.
As for gears I dont like richmond had them in a few different cars and they tend to be noisey.
