4l80 experts come in
Old Dec 11, 2011 | 12:13 PM
novaflash2002's Avatar
Default 4l80 experts come in
I was wondering what the difference is in the 1991-1996 4l80 verse the 1997 plus. also was wondering if i can get the 1993 vintage year into a 2001 camaro... or do i need to find a newer one? thanks
Old Dec 11, 2011 | 02:12 PM
DietCoke's Avatar
The case is different, bolt holes on bellhousing are in diff spots, but you still only end up using 5 of them. Some internal changes, wiring harnesses and valve bodies are slightly different (use a new/modern internal wiring harness if possible) but they are mostly quite similar once you go through them and update/rebuild em.
Old Dec 11, 2011 | 02:16 PM
was wondering about the internal harness.
Old Dec 11, 2011 | 08:17 PM
SnIpEz's Avatar
Overdrive gear is also stronger on the older models I'd like to add.
Most people purchase older style 4L80E's honestly
Old Dec 11, 2011 | 10:58 PM
Cam72aro's Avatar
I have one from a 95 g30 van. We will see how strong it is pretty soon.
