What is this on my 4L80E flexplate?
I am running a powerglide to a 1999 long crank LQ4 (no spacer, but physically longer crank). I was told I need a 4L80 flex plate. That is how this one was described. However, it did not have a picture of the plate before I bought it. Nor did it say it was for an externally balanced engine.
I may just bolt this one up, see if my converter and starter line up like I am hoping they will, then if they do, I know I can use a flex plate with these dimensions.
Thanks for the replies guys
just go to the dealer and get one for a 6.0 w/4l80e-if you have a long crank, you wont need the spacer
