Help pin point what needs to be fixed now
Old Dec 28, 2011 | 10:03 PM
chris95lt1ta's Avatar
Default Help pin point what needs to be fixed now
After my car heats up on normal driving the transmission jerks into 3rd gear. And then stays in 3rd. When i leave red lights and stop signs i have to give it alot of gas to leave. And at WOT from a stop it doeznt even spin. Please help guys i know nothing about transmissions. And i took it to a shop around here and the mechanic said drop the pan change the filter and fluid. I was planning on doing this tomorrow but i would like some input before. Stock a4. Any suggeztions will help thanks!
Old Dec 29, 2011 | 05:47 PM
Well i changed the filter and fluid. Problem is still there. Im going to buy new shift solenoids and a revmax stall hopefully that will clear out the problem. Any suggestions or tips would be awesome. Thanks.
Old Dec 30, 2011 | 09:58 PM
gofasterdammit's Avatar
you should have the car scanned to see what codes you have.
Old Dec 30, 2011 | 10:08 PM
Vince B's Avatar
Moderator
^Do this first!
