4L80E Neutral safety switch connectors
http://www.electricaladvantage.net/4l60e4l80emlps.aspx
The harness repair kit is listed on that same page, below the PRNDL switch. Total for all parts a LOT less then your quote. Hope this helps
Luckily they're only needed on trucks, so cars and most swaps dont reuse them. Your PCM wants a P/neutral signal, so hook that to your shifter. Rest can be ignored
Swap harness will only have provisions for the P/neutral switch
Also, Thanks, Pocket. Your thread on connector cross references on 3rdgen was helpful in getting me started.
Jay
I much rather have the '04 & up "Delphi" NSS! You just have to wire in a relay for the solenoid load (If this is a swap vehicle or a GMT400 truck).
In fact......If you don't have the engine in a '94-'08 GM truck or a '97-'05 Corvette....You don't need the trans mounted NSS. Let your shifter handle that if possible!
then simply re-wire it to your harness when ready. This way no fooling with glue.
figured it out after destroying two ofthem trying to get those plugs out. I thought it was a fluke the first time, "what the hell is this ****?!" but when I noticed they all had it I realized I needed a new plan. lol
I'm not carrying an electrical, battery powered heat gun into that place...
just cut the wires and run for yer life
I actually bought a switch and the pigtail ( I only bought one that has the reverse lights in it as that was all I needed it for in my application ) , off eBay and they worked just fine. Connector came with a good pigtail of the wires and nice connectors to make the connections with and heat shrink.
