TH400 Guys; What Flexplate do you use?
Old Jan 5, 2012 | 01:44 PM
IT_SS's Avatar
Default TH400 Guys; What Flexplate do you use?
Hey fellas, looking for a flexplate to use with my 370, I keep seeing mixed reviews on the TCI.
Old Jan 5, 2012 | 01:46 PM
WheelsUp84z's Avatar
I have the TCI one on mine. 890-399753 is the PN on my invoice from Jegs. Paid $214 for it.
Old Jan 5, 2012 | 03:46 PM
wreckwriter's Avatar
Mine iswn't together yet but planning on this one:
http://www.tciauto.com/tc/engine-pro...-approved.html
Old Jan 5, 2012 | 04:10 PM
midwestjunk's Avatar
I have circle d sfi flex plate and converter. Direct fit.
Old Jan 5, 2012 | 04:20 PM
Circle-D's Avatar
This is our version of the perfect LS flexplate. Billet aluminum, offset built in, CNC machined, every GM bolt pattern. No issues with the converter bolts rubbing the block like you might have on other models.
http://www.circledspecialties.com/p-...flexplate.aspx
Old Jan 5, 2012 | 04:21 PM
Circle-D's Avatar
Thanks
Chris
Old Jan 5, 2012 | 04:27 PM
IT_SS's Avatar
how about this one? http://www.circledspecialties.com/p-...lex-plate.aspx
Old Jan 5, 2012 | 04:43 PM
Circle-D's Avatar
That one work as well, if the converter has the dual bolt pattern on it. THe Stamped Steel one only has the LT/350 Bolt Pattern. So if your converter has 2 holes per lug, then you should be good to go. How much HP are we talking?
Chris
Old Jan 8, 2012 | 01:46 PM
IT_SS's Avatar
Chris
1000 crank
Old Jan 8, 2012 | 01:51 PM
Circle-D's Avatar
Originally Posted by IT_SS
1000 crank
I would go with the billet aluminum. The stamped steel one is SFI approved, but if you are over 750 I suggest the billet one. Peace of mind....
Chris
