95 PCM and 4L80E
Old Jan 7, 2012 | 06:14 PM
Shownomercy's Avatar
Man-Crush Warning
Default 95 PCM and 4L80E
Can it be done via the LT1 PCM and the needed rewire of the trans harness?
I cannot seem to find a straight 100% answer on whether the tunercat software will do it.
Old Jan 15, 2012 | 12:49 PM
Pocket's Avatar
You cannot repin the LT1 PCM to the 4L80E and there is no segment to control it. You may have luck with the relay trick using a 4L60E segment and wiring
