Noob 700r4 questions
Any links? Prices?
Also what cooler and stall should I go with? I was looking to get around a 4000 stall. It's somewhat of a budget build but I don't want junk.
Thanks!!
As far as the trans build, the 700R4 if going to have almost all the same parts as any 4l60E build. The valve body is important in these since the 700R4 isn't electronic. Just don't cheap out whatever you do, and you should have a great trans that will stand up to plenty of abuse.
My mild build 700r4 died twice at 400rwhp both times losing 2nd gear.
I just got my Revmax 3600, and I have a full 383 stroker build with a heavy cam, built trans, built rear ect. I wouldn't have gone higher. It all depends on your car. You choose your stall speed to get and keep your car in it's power range. So you you really want to be at 4000 rpm?
For a Stage 3 Revmax with any stall speed, depending on what upgrades you buy, you can expect to pay from 300-600. My car is making a little over 400rwhp NA, no nitrous or anything but I do drive it on the street alot, so I didn't need any upgrades, just a carbon fiber lockup clutch for street driving. I payed a little over $300 shipped when they were running their sale on here.
Also don't forget the higher the stall you go, if you're sticking your launches the more stress is going to be put on the drive train. Do you have a 10 bolt rear still? If so, don't expect that thing to last long leaving the line at 4k rpms with a sticky tire.
