High Stall TC
Tranny Cooler?
Tuning?
Shift-Kit?
Drag tires?
for the high stall T/C if i just had Wet and Dry tires....woudl it be ok with the higher stall TC?
Tuning?
Shift-Kit?
Drag tires?
YES ^^
don't even think of driving around with a high stall and street tires, you'll kill yourself, even with nitto's at 25psihot, i find the ASR coming on esp if i tip in too much on corners (taking off) or if i want to flog it.
big converters are pretty sketchy in the rain if you tip in too much even with nittos that are fresh.
i spose if your used to driving in northern weather no biggie, but its dry most of the year down here if we see ice once every few years in a spot we're lucky.
makes sense to me, dunno why they just didn't put it down that way on the shifter? the ecu doesn't say OD
What happens with the higher stall? Is there an initial Mushy Pedal ever, or just head snapping jolts? What is this about Hp loss with TC..or am I totally off? And what suspension mods would you recommend with a daily street driver with a 3200 Vig?
once the car locks up, it drops to 1000rpm and the car kinda puts.
Don't worry about hp on the A4. it's all about the 1/4 mile times. A stall on an A4 makes it a muscle car/strip car. Go to the track, get a #. M6 folks are the ones that are dyno queens
no excuse with a stalled a4. You'll find it takes a helluva lot less power than you think to pull some mad 1/4 mile times. I suggest: Not lowering the car, Buying spare rims (2) and throwing ET slicks on, Getting a Line lock (for the et's), Running 555R Drag radials on the street so you don't die, lca, panhard bar. Almost everything you do to add handling will almost always (but not always) reduce your drag potential.
Ie those 60K old shocks may be better off than brand new bilsteins.
I doubt SFC's and STB do any good on drag racing, but add weight. Weight = evil
you are somewhat correct that the torque converter is like a light switch, you mash it, it lights up the tires, you can baby it and drive it pretty normally, but the car will be loud as hell until you reach lockup do to the loose-ness.
