Stock Trans Cooler HELP
Old Feb 17, 2012 | 05:07 PM
YoungGun496's Avatar
Default Stock Trans Cooler HELP
I am putting a Converter in my 02 Firebird and installing a aftermarket trans cooler as well. Were I live, we have some pretty cold winters and I drive my car anytime there is not snow on the ground. So I am going to run the stock trans cooler in conjunction with the aftermarket cooler. I am wanting to run braided AN line for the whole system.
My question is, the stock cooler takes a inverted flare that treads in. Do they make an adapter fitting what will screw in the stock cooler and with a 6AN male for my braided line? If so, what is the thread size?
I know the common thing it to cut the factory hard line going into the trans cooler and slide a hose over it with hose clamps, but I don't like that setup. So that's why I am wondering if there is a fitting that will screw into the stock cooler that has a 6AN male flare. Much cleaner look and less likely to leak!
I did tons of searching but could not find a thread with this information
I appreciate any and all help!
Thanks
Old Feb 17, 2012 | 05:30 PM
I think it might be 5/16" inverted flare... Forgot to put that in my OP. So would a 5/16" inverted flare to a 6AN Male work for this setup?
http://www.summitracing.com/parts/EAR-991946ERL
Old Feb 19, 2012 | 06:04 PM
i figured it out... Thanks for the help...
