Avg temp with stall
Old Feb 18, 2012 | 02:48 AM
ls1wallen's Avatar
Default Avg temp with stall
I just wanted to know what is your avg temp is your transmission running at after you installed your stall? Ive seen a couple cars running lower temps then stock with a nice cooler.
Old Feb 18, 2012 | 03:52 AM
01ssreda4's Avatar
I have a pretty big B+M cooler. Trans temp as measured at the pan varies greatly depending on outside air temp, especially since deleting the stock cooler out of the equation. So for 30-50 outside temp, I see a maximum of 120 on the hwy. For 50-70 outside temps, I see about 145 on the hwy, and for 80-100+ summer time heat, I see 160-170 on the hwy. During extended idling, it will reach 190 no matter what the outside temp is. But, the cooler the outside temp, the longer it takes to get there.
