Installing tranny cooler
Old Feb 19, 2012 | 08:13 AM
camarovon's Avatar
Default Installing tranny cooler
Do I just cut the ends off the lines that are going to the radiator,and hook them to new tranny cooler
Old Feb 19, 2012 | 10:32 AM
steves2002z28's Avatar
On my 06 trailblazer trans lines were rotted n i cut off where solid flared ends double clamped over a year ago n havent had problems
Old Feb 19, 2012 | 06:21 PM
Leeroyws6's Avatar
you can.or you can use the stock cooler with the new cooler which is what most people do.
Old Feb 19, 2012 | 09:13 PM
peterlawl84's Avatar
No need to cut the lines, you can either run it in series with the stock cooler or replace the stock cooler.
Here is what I did:
https://ls1tech.com/forums/13327152-post11.html
