4L60e will not upshift at WOT
I sent my PCM for reprogramming for headers and the convereter and the WOT problem and that didn't fix the problem. I took the car back to the transmission shop today went for a test drive with a scanner and my mechanic said the PCM isn't commanding the transmission to upshift at WOT and it's a computer problem. TPS voltage is correct, I had the PCM reprogrammed over two years ago when I had an LS6 installed and it shifted perfect up until that day I noticed it would not upshift. My tuner said it's not a programming problem but the PCM itself is faulty.
Before I shell out a few hundred bucks on a used PCM does anyone have some suggestions?
The '99 PCM has a completely different wiring pinout, even though the connectors are the same. The best way is to buy new connectors ($50?) and move all the wires one by one from the old connectors to the new ones. There are several guides posted on the Net for doing this.
Personally I would switch to the '02 PCM which some say is the latest-and-greatest for that generation engine. However you should definitely get other opinions on that.
I assume the mechanic has some type of scanner on board; it's not hard to check this with a good scanner; this should rule out the transmission. It could still be a sensor problem (TPS or VSS), but again a good scanner should indicate whether these are working.
Yup, I'm leaning toward something inside the PCM itself...it did it before the trans rebuild..started doing it a year and a half after the first tune and still does it after the retune...I'm going to take it to another trans shop by my house just to get a 2nd opinion before I buy another PCM.
I agree with lt1pwr1 that your PCM is probably fine if it shifts at all but WOT.
Either a sensor is off, the tune is wrong, or some combination of the two.
Its been a year since I last played with forced shifting in the HP Tuners scanner, but a trans shop should have such a tool. If a scanner can force shifts into each gear, then generally your trans and pcm are working fine.
It seems we had a very similar thread here in the past few months.
I have to agree with the tuner not being the tune...it shifted fine with the retune for a year and a half then all of a sudden it wouldnt shift at WOT.
Lets assume it is not the trans...
In WOT mode the PCM needs two (tuned) parameters to make a shift - speed and RPM. If either is not above the tuned value, it will not shift, no matter how high the other value is. On the other hand, when you are not at WOT, then only speed is needed to make the shift. The tune also determines what throttle percentage is considered "WOT". I don't see how the PCM could get the wrong RPM and still run the engine. I don't know how/if a flakey VSS could send the wrong signal to the PCM and still have the speedometer correct??? Somehow it still seems related to the TPS and VSS sensors and sabersaw30 claims a TPS change fixed his problem. Again a good scanner and moderately experienced user should be able to troubleshoot this quickly.
Also, in another recent thread the author is now pretty sure that his tune did change (drastically) when his battery went dead; he also could not shift at WOT.
Perhaps a trans expert here will have the magic solution.
