02 HD - 4L80E Weak Reverse
Old Mar 2, 2012 | 09:52 AM
Strokinit383's Avatar
Default 02 HD - 4L80E Weak Reverse
I picked up a 2002 2500HD a few months ago. Ive noticed that something is not right with the reverse. It struggled to back up an inclined driveway and could barely back over a hump in the road. I almost have to put the pedal to the floor to get it to move. After I left off the gas I hear a thud. No problems backing up on flat surfaces and no problems with any of the forward gears.
Any ideas?
Old Mar 5, 2012 | 07:24 AM
Bump...anyone?
Old Mar 5, 2012 | 10:08 AM
slow67's Avatar
Gingervitis Addict
As in its slipping or feels like its trying to lockup?
Old Mar 6, 2012 | 07:23 AM
What would be locking up in it? If its slipping, I've never felt a trans slip like this. It's not intermittent at all. It just feels as if it can't put the power to the tires.
Old Mar 6, 2012 | 04:48 PM
cabel1's Avatar
My 4l80 started slipping in reverse last year and I had to install a longer reverse servo pin to get it to work properly
Old Mar 7, 2012 | 08:01 AM
Interesting. What were the symptoms cabel1? I need to do a little research. Did you have to pull the trans for that or could you access it through the pan?
Old Mar 7, 2012 | 07:50 PM
cabel1's Avatar
Sometimes it just wouldn't grab in reverse other times it seemed ok but weak. You need to pull the valve body to get the reverse servo out. GM makes a tool to check what length you need
Old Mar 20, 2012 | 02:33 PM
Turns out it is slipping. I tried to back up my driveway this weekend, which is at about a 20 degree grade, with over a ton of retaining block in the bed and it almost didnt make it up.
