Try to follow... AOD behind turbo LS?
Old Oct 29, 2019 | 11:37 AM
vorteciroc's Avatar
Even worse than an aftermarket Ford 9" differential... Guys on here install aftermarket Dana 60 differentials in there cars with engines making very little power!
Mean while they complain that a 4L80E will be too big and consume too much power... Using a Dana 60 would be significantly worse!
Also, just so you guys know... My 4L80E transmissions consume less power than a stock 4L60E transmission on a chassis dynomometer.
So quit trying to use that as an excuse not to install one.
On that note, if you guys are soo worried about power consumption... I would look at a GM 12 bolt way before a Dana 60!
