flare nut on the hard line
Old Mar 26, 2012 | 02:35 PM
zooguy's Avatar
Default flare nut on the hard line
does any one know what size the flare nuts are on a 1995 4L60e hard line?
last time my tranny guy did some work he used a set of pliers or some thing to tighten down the flare nuts and thus stripping tthem so bad a wrench wont work any more.
Old Mar 27, 2012 | 01:47 PM
zooguy's Avatar
no one has any idea?
Old Mar 28, 2012 | 07:25 AM
zooguy's Avatar
nearly 100 people have looked at this and no one knows the answer?
Old Mar 28, 2012 | 09:06 AM
mrvedit's Avatar
Moderator
Not to be mean, but I suspect that 100 people don't understand your question. "the nut that holds the tranny line"???
I will assume you mean the cooling lines.
Assuming true, the following thread should help you fix your problem; start at post #19:
https://ls1tech.com/forums/automatic...nes-4l60e.html
Old Apr 8, 2012 | 06:55 PM
zooguy's Avatar
bump
i need to know the size of the actual flare nut on the hard line
Old Apr 8, 2012 | 08:35 PM
GMRACER13's Avatar
They are 1/2".
