LQ4 4l60e swap
I've got an LQ4 out of an 06 Chevy 2500, and the complete computer and wiring harness out of 05-07 Escalade. (He couldn't remember if it was one year newer or older, long story)
From what I understand the computer should be for a LQ9 backed by a 4L60e. Anyone know how true this is?
If that's the case, I know the computer wiring harness has a plug that goes to the transmission. Will it plug into the trans wiring harness? I knew some years had separate controllers and some ran off the ECU. Does anyone have a break in years for which ones which? Are all 4L60e trans the same?
Thanks
All 4L60E have the same connector. All years from 1996 thru 2008 are basically the same, although 2003+ have some improvements to handle more power.
I'm no expert, but I think you are good to go. (Unless an expert here corrects me.)
Was hoping a few more people would chime in. ttt
