Lockup trouble, need ideas !
Old Apr 15, 2012 | 10:27 PM
soundengineer's Avatar
hell.. I forgot about the misfire tables too...
Engine Diagnostics tab...
High middle and low...
usually the middle table... you can usually just increase all teh values in that one to double and that will fix it...if not.. keep raising it till it goes away and your lockup comes back.
Old Apr 15, 2012 | 10:33 PM
Golf&GM's Avatar
Here ya go, its actually a sticky in this section. Here's what I set my values to, not sure how a cam would affecting this, but might be a good starting point. https://ls1tech.com/forums/15511282-post24.html
Old Apr 16, 2012 | 08:51 PM
joecar's Avatar
If P0106 does not come back then could also try a CASE relearn prior to adjusting the misfire thresholds to see if that helps.
Old Apr 21, 2012 | 06:05 PM
hilio's Avatar
Thanks guys for all the help, it was the misfire table, fixed it and now it´s locking up. I´m still having some trouble with the MAP though !
