Something Electronic with Transmission
Old Apr 16, 2012 | 10:14 PM
94LT4Corvette's Avatar
Unhappy Something Electronic with Transmission
So I've got a problem that started about a couple weeks ago and has got worse. At first when I shifted the auto into Drive or 3rd it was fine most of the time... a few times it would slightly hesitate and not want to go it seemed until I shifted the stick into another gear. Well now it's like randomly just going into neutral or something when I go... I can drive normal for a few seconds... maybe a min or two... and then it acts like the thing isnt in gear anymore and just revs up... and then none of the gears work at all... so I would pull over... turn the car off and restart it and behold I could drive again until it started doing the same thing a few moments later. I have no idea what it is... not a mechanic for starters... lol. Also seems to be at its worse after it has been in gear and when I stop at a light... when I take off... its no longer giving me any push... just the revs again. If anyone knows what this is? I'm hoping somekind of sensor or wire... lol... let me know... I need to get me a mechanic to fix it ASAP... midterms in my classes are this week in college... sucks for me right now.
Old Apr 17, 2012 | 05:55 PM
mrvedit's Avatar
Moderator
Step one - check your trans fluid level. (Sorry if you already did this obvious step, but you didn't mention it.)
After that I think you need to take it to a trans shop; it sounds like it has low line pressure which can be any number of things. If it is an original '94 it has weak parts in the oil pump and would need a rebuild. Sorry not to have better news.
Old Apr 17, 2012 | 10:17 PM
Yeah I called the mechanic today... and when I told him about the whole "neutral" thingy happening to me... he knew what it was... the Torque Converter... basically though the options are "Hope I'm lucky and it hasn't contaminated the rest of the transmission and I can just replace that part" or "rebuild" but thanks for response... I would never have guessed that part even after I read up on it... but it makes sense that its "disengaging" when it gets hot cause it doesnt happen until I've driven it at least 10 to 15 minutes.
