top end speed compared 4l80e to 4l60e
Once it reaches 3rd and then overdrive would the car continue to keep the top end speed gain ? or would it just come down to the same final gears still being the same and end up equal,other than car just staying out ahead keeping the distance between them ?
4L60E 4th is 0.70:1
4L80E 4th is 0.75:1
IIRC
Edit: The lower gears are longer, i.e. 1st and 2nd will take you to a higher MPH in a 4L80E than a 4L60E (asssuming everything else stays the same)
4L60E 3.06 1.62 1.00 0.70
4L80E 2.48 1.48 1.00 0.75
