new trans, need help please
Old Jul 15, 2012 | 03:42 PM
dans94z28's Avatar
Default new trans, need help please
okay so new transmission is in and still having a issue with shifting. its a stock rebuilt replacement and the price was right for my budget or i would have had a good built transmission installed. my problem is when I drop it to first and go through the gears manually from a light it gets stuck on the rev limiter at the end of each gear before finally shifting. the 2-3 shift is really bad. would installing a shift kit eliminate this problem? I plan to have my torque management turned off and the rev limiter raised as well as some other things next weekend with a hp tuner. can it be helped with the hp tuner?
Old Jul 22, 2012 | 08:38 PM
dans94z28's Avatar
long story short, new transmission is slipping really bad and is no good.
