If I Did Change...
Old Apr 3, 2004 | 05:00 PM
BoneSS's Avatar
Default If I Did Change...
Quick question, what difference do you notice with a bigger stall? I have a Vig 2800 now, but have I have been wondering what changes I would see in driving, rpms, shifts, traction, by going with a bigger stall?
Old Apr 3, 2004 | 05:09 PM
maron blur's Avatar
just changed vig 2800 to vig3600 not enoughf differance to even tell but definitely a diff. in performance
Old Apr 4, 2004 | 08:26 AM
BoneSS's Avatar
Could you be more specific?
Old Apr 4, 2004 | 09:39 PM
BoneSS's Avatar
Anyone else have any opinions?
Old Apr 5, 2004 | 06:56 AM
boomcase's Avatar
You would have a looser feel at take off for normal driving , Once the converter locks it will feel just like your 2800 does , performance would depend on your Tires and traction, shifts will feel alittle softer , And your shift extension will be higher which is good because your motor will not drop as much rpm when it shifts and have to play catch up back to its power band.
Old Apr 5, 2004 | 11:26 AM
Ed Blown Vert's Avatar
I have been thinking about the same change. Just worried that N20 will make the stall too high.
Old Apr 6, 2004 | 09:37 AM
BoneSS's Avatar
Ed, I know your Vig is track tested, does it stall around 3200 for you? The only reason I have considered a little bigger stall, may be a 4000, is to run a bigger cam. I am thinking that something like a 229 or 230 is going to be as big as I am going to be able to go with this stall. Thanks boomcase for the excellent explanation.
Old Apr 6, 2004 | 01:08 PM
When I get home. I'll check my EFI Live recordings.
Old Apr 6, 2004 | 08:04 PM
NA it flashes around 3200-3400.
Old Apr 6, 2004 | 10:00 PM
BoneSS's Avatar
Thanks for going to the trouble and checking for me Ed. It is nice to talk to someone with the same stall, and someone who actually has used it properly Nice ride by the way.
Old Apr 6, 2004 | 10:47 PM
No problem. Going to practice my launches this Fri on my ET Streets
Old Apr 6, 2004 | 10:52 PM
BoneSS's Avatar
What kind of 60' do you hope to cut?
