vigilante out of balance?
I wish they would just admit the motor is out of balance. Either the factory balancer is not doing it's job or the crank is unbalanced. Of course, the ever wonderful piston slap is probably not helping.
97Silverbullet - A converter is definitely the single best mod that I have done to date. I would definitely do it again. Although, with the lack of other mods on my car, the 3200 stall is a bit much for everyday driving.
In the current issue of HotRod,(yeah I know
), the part towards the back where people write in problems with their cars has a blue box surrounding a message written by a GM tech. In that message he describes a similar problem with a 3d gen Camaro with a 700R4 transmission. Since our trannys are basically a 700R4 with electronics, I could see this being relevant here. I apologize for not having more info on this. If anyone has this HotRod and can transcribe the mechanic's wording I think it would be beneficial for all to read. I will find the issue tonight and type it in, unless someone here can (hopefully) beat me to it.
Tony
. This is driving me nuts
. Last edited by CamaroSSdotcom; Apr 15, 2004 at 08:14 AM.
.The Best V8 Stories One Small Block at Time
Anyone else try it with the converter off to see if they still have the vibration?
FYI - We turned my converter as well and it just moved where the vibration occurred in the RPM band. It moved from 1800-2000 to 1600-1800. The over 2500 was still there.
Maddboost: If you prefer, I will refrain from posting anymore to this thread.
Just trying to help...
Like I said before, if we had not pulled the converter off and got the same vibration, I would be more likely to blame the install, the converter, or the flexplate.
I think you may be sending (reader) on the wrong track in your vibration concern on his 88 IROC. ("Driveshaft Vibration" Pit Stop Oct 03). He supplied you with clues that point more toward the trasmission as the culprit rather than the driveshaft or rearend. First, he states that the vibration is not present in Third gear at the same speed. Second he states that the vibration is not present in Neutral at the same speed. This is a very important check in diagnosing a speed-related vibration. You can generally eliminate a driveline vibration with this test. A tire/wheel/propshaft vibration that occurs at a given speed will resonate under accel or decel. If the vibration is present in Neutral when coasting down through a given speed, you can usually eliminate these items.
That is why I beleive that he has a fault in the reaction planetary gearset in his transmission. When his trans is placed in Neutral, the drive wheels are turning the axles, differential, and driveshaft. In turn, the transmission is in Third gear, there is no gear reduction through the transmission, giving a 1:1 ratio, meaning that the reaction and input planetary gearsets are all turning at the same speed.
(reader) primarily feesl the vibration under load in fourth gear. since we've already eliminated the input planetary (as the vibration doesn't occur in Neutral), this leaves the operation of the reaction planetary gearset as the probable source of the problem. The fact that (reader) also said that he heard a faint "beating" sound in second gear at 2700 rpm only reinforces this belief, as the reaction Sun gear is held in both Second and Fourth gear by the 2-4 band. As for why (reader) didn't encounter the problem before he switched rearend gears: Most probably, he simply moved the peak resonance of the vibration to a point at which it was more noticeable.
Scott Wagner
Service Technician, ASE Master Technician, GM World Class Technician
Michael Chevrolet
Summerville, SC
Hot Rod Magazine, May 2004 pp106
1. Freshly built motor with balanced rotating assembly...I know this is not the problem. I had the same vibration with my 383 that I do with the 385.
2. New flexplate. I scrapped the stock flexplate and installed a TCI SFI flexplate...that didn't fix it either.
3. Transmission rebuild...my mechanic went through the whole thing (long story on how it broke) and replaced everything that was screwed. The vibration was still there afterwards.
4. Spun the converter to different bolt holes...didn't help at all.
5. Switched from 3.42 to 3.73 gears and installed a new posi...this didn't fix it either, although it seems like it made it a bit worse.
6. It's not the torque arm mount...I have a Jegster torque arm and this vibration was never a problem until I got the Vigilante. I had a couple of crappy TransStar converters prior to this one (2400 and 3000 stalls) and neither of them vibrated like this. Then again, they were 12 inch converters and the Vigilante is a 10 inch, so maybe that makes a difference.
I'd like to hear more about the washers in between the flexplate and the converter. Has anyone tried this, and has it worked out? I get a "clunk" noise on 1-2 upshifts and 2-1 downshifts, so I'm wondering if the converter isn't back far enough on the input shaft or something.
