4l80e cross member
Old Sep 13, 2012 | 04:38 PM
gpr's Avatar
gpr
Default 4l80e cross member
I need a crossmember for the 4l80e i'm swaping into an f-body. Does anyone make one that lets you mount the torque arm to it?
I have read MWC crossmember requires the use of a short torque arm, which I don't want to do. Also the BMR one doesn't look like it has provisions for the torque arm mount.
Old Sep 13, 2012 | 08:30 PM
mike13's Avatar
My BMR cross member fit fine. I had to trim the lip of the pan but it wasn't bad.
Old Sep 14, 2012 | 07:17 AM
Mystery Bird's Avatar
Has anyone cut up and rewelded a stock one sucessfully?
Old Sep 14, 2012 | 07:55 AM
White.Lightning's Avatar
BMR and Yank make a 4L80e crossmember with an option for stock torque arm mounting.
I asked MWC about that "option" and Eric said there isn't enough room to run the stock torque arm. Could this be an up-sell into his torque arm? Possibly.
I haven't had the chance to visually see the clearances myself just yet. But I will note that "most" that run 80e's have aftermarket torque arms of some kind- all chassis mounted.
As far as hacking up a stock 60e crossmember, I haven't seen anyone do that for an 80e application since the 80e is longer than the 60e. Anything can be done with a welder and some metal though.
Old Sep 14, 2012 | 08:15 AM
RedRocketZ28's Avatar
My BMR fit perfectly fine. They have since fixed the issues that some were having.
Old Sep 14, 2012 | 08:32 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
We have definitely fixed the clearance issue with the BMR 4L80E torque arm relocation crossmembers that we had issue with a while back. The 4L80E transmissions are so big that everything has to be positioned just right to make everything fit without any clearance issues. As far as I know we have taken care of everyone that has contacted us with issues on the 4L80E crossmembers.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
