4l60e problems!! Help
If the shop recently did not remove the trans to really fix the flare, then they likely just increased the line pressure (by stretching a spring) which reduced the flare, but didn't solve the underlying problem.
The solution is to rebuild the trans with performance parts. This would include at least a 4l65E rebuild kit (which has a better 7-friction 3/4 clutch), a Borg Warner sprag, a stronger SunShell and a 0.500 boost valve. Options would include 5 gear planetaries, input drum reinforcement and the Transgo HD2 shift kit.
Check out this similar recent thread:
https://ls1tech.com/forums/automatic...i-rebuild.html
As mentioned there, ebay seller TrueTechTrans sells very complete kits with all the parts I mentioned. Sure, you could save money by buying individual parts from Amazon, the dealer and online stores, but buying a kit with matching parts is a safer bet.
Even then, you might want to find a local builder with some experience building a performance 4L60E with such parts. Based on reading many threads here and helping a bunch of people myself, I estimate that fewer than 50% of people get their first trans rebuild to work. Any mistake, mismatched part or overlooked problem will mean removing the trans and rebuilding it again, which quickly increases cost and aggravation.
I would start by installing a 0.500 boost valve, which only requires dropping the pan.
Second, I would install the Sonnax Servo Check valve:
http://www.sonnax.com/system/announcement/77701-076.pdf
However this requires dropping the valve body and also drilling the separator plate. Without this valve, I would still drill out the 3rd feed hole on the separator plate to make sure it is at least .082.
It would also be good to know whether you have the standard or the Corvette servo. In fact you need to know this when installing the Sonnax Servo Check valve. If you pull out the servo, which is hard in some cars and easy in others, also replace the seals as any leak here will cause various 2/3 shift problems.
If none of this solves the problem, then a trans rebuild may be needed. Go with a 7 or 8 friction 3/4 clutch and a tighter-than-stock clearance.
I'm no expert, so get other advice too.
