how to remove trans line fittings?
you do not un screw the fitting, to re install the line re insert the c clip back into the fitting then slid/push the line back in, slide the plastic washer/cover back over the c clip
do not know about the leak, I would clean the line with brake clean or something and be sure where it is leaking
hope the helps, Johnny
