whats wrong, TC or tranny??
Old Oct 17, 2012 | 06:02 PM
mrvedit's Avatar
Moderator
What year is the used 4l60e for $200$ ??
It needs to be a '98 or later with the bolt hole in the 12 O'clock position which indicates it has a 300mm input shaft.
Old Oct 17, 2012 | 07:19 PM
PaSteLaSo4U's Avatar
its from a 99 ws6
Old Oct 18, 2012 | 10:08 AM
mrvedit's Avatar
Moderator
You PM'ed me several Craigslist entries and I would pick the 2002 trans from a Z28 for $350.
At least get the fluid and filter changed. Also the little O-ring on in the input shaft. Based on other posts where people had leaks with junkyard transmissions, you might want to replace the front and rear seals, the O-ring for the connector and seal for the dipstick tube.
Old Oct 18, 2012 | 11:10 AM
thanks. should I buy a line pressure booster to help with the vig 3800 stall?
Old Oct 18, 2012 | 11:38 AM
mrvedit's Avatar
Moderator
A .500 boost valve is a good idea for any performance transmission and very simple to install. You want the Sonnax 4L60E-LB1:
http://www.sonnax.com/system/announc...0E-LB1-LB2.pdf
http://www.sonnax.com/system/instruc...LB1-LB2-IN.pdf
If you can spare another $100, I would replace the shift solenoids, the pressure control solenoid and the wiring harness, which includes the TCC solenoid.
