4L60E Front Pump Clarification
Old Oct 1, 2012 | 10:10 AM
aschoon85's Avatar
Default 4L60E Front Pump Clarification
I am a 4L60E Newb, and did the stupid "install torque converter wrong and break crap" trick...
I am trying to find a new front pump after finding that I broke the drive teeth off. I have an LS1/4L60E out of a 1999 Trans Am and if I am reading everything correctly, I have a 300mm-type pump?
If that is correct, are all 300mm pumps created equal, or are there specific pumps for the F-Body cars?
Is there a part number that I should be looking for?
Please help as I am in desperate need to find a new pump and get my street rod assembled!
Old Oct 1, 2012 | 10:58 AM
aschoon85's Avatar
I just talked to someone at PerformaBuilt and they confirmed that they are all 300mm pumps and they are all the same. Thank you to the Tech support at PerformBuilt Transmissions for your help!!!
