Corvette Servos
Old Oct 5, 2012 | 07:35 PM
bluebird71's Avatar
Default Corvette Servos
I am putting a Transgo HD2 and Vette servo in the 4L60 in my '03 Silverado. I already ordered the Vette servo, but now I'm wondering if I need another one as well. The description said "2-4 Corvette Servo" and the part # on it is A74907B. I assumed that "2-4" meant that it controlled ALL the shift points, including 1-2. I know there is an aftermarket 4th gear billet servo, so are there 2 different Corvette servos? Will this one help my 1-2 shift, or will I need another one on top of it? The item came with 2 individual pieces to it.
Old Oct 5, 2012 | 07:51 PM
mrvedit's Avatar
Moderator
There is only one "Corvette servo" which has a bigger apply area for the inner piston. Many people call this the "2nd gear servo", but it is actually applied in 2rd, 3rd and 4th gears. There is a 4th gear billet servo available, but IMHO I don't see any reason for it unless you are track racing in 4th gear at WOT (120mph+).
Note that the HD2 kit specifies the WHITE Accum spring in Step 4 Page 2 for the Vette servo. Also I would recommend then drilling the 2-3 shift hole to .101 (Page 4).
Old Oct 5, 2012 | 08:16 PM
bluebird71's Avatar
Awsome, thanks for the advice. I also went ahead and got the Sonnax servo release check valve to go in there as well.
Old Oct 5, 2012 | 10:20 PM
mrvedit's Avatar
Moderator
Excellent choice. Note that with the Vette servo, the orifice hole on the release valve needs to be drilled to .120; I first drill it to .100 and then to the final .120. As instructed, I then drill the 2-3 feed hole to .125 (same as 1/8").
Note: The HD2 kit includes drill bits .082 and .091. You might want to buy .100, .110 and .120 ahead of time. I bought a complete set of bits from Harbor Freight.
If you want, PM me and I will be happy to give you my phone # in case you need assistance.
