b&m deep pan install ????
Old Apr 9, 2004 | 11:50 PM
more carbon's Avatar
Default b&m deep pan install ????
the kit filter fitting extension seems loose where it mounts to trans as it will not hold up the filter.do you need to use a new pump seal every time you change the filter???? does the filter sit on the pan floor???? anyone do this mod???? any help thks much!!!!
