4l65 in a 98 z28.....
Old Oct 14, 2012 | 03:25 PM
SHDY 5.7's Avatar
Question 4l65 in a 98 z28.....
Is this possible? Anything have to be changed,etc?
Thanks,
Dale
Old Oct 14, 2012 | 03:50 PM
thehulk2203's Avatar
It should work just put a 4l70e came out of a 2008 trialblazer ss had to change the rear tail housing think that's what its called. OTher than that everything else bolted right up
Old Oct 14, 2012 | 06:52 PM
Vince B's Avatar
Moderator
You will want to swap the linkage shaft as well but physically the trans will bolt up without any other external changes. I would recommend installing a shift kit to tailor the separator plate, the accumulators and also I would install a vet servo. Personally I have been using the sonnax kit in these units and have received some great results. I would add to their kit a set of abuse plugs for the valve body and a hd 2-3 shift valve to make a nice well balanced transmission. HTH Vince
Old Oct 15, 2012 | 06:25 AM
SHDY 5.7's Avatar
Vince, its a fully built rpm trans w/a converter. I just didn't know if it would work.
Old Oct 15, 2012 | 07:00 AM
Vince B's Avatar
Moderator
As I said the linkage shaft is the only concern I would have. All the mods are already built into that unit so you are good to go.
Old Oct 15, 2012 | 12:51 PM
SHDY 5.7's Avatar
Thank u Vince.
