circle d th350 coverter question
Old Oct 14, 2012 | 08:37 PM
Rpayne41985's Avatar
Default circle d th350 coverter question
I have a circle d stage 2 converter that was set up for my cam only set up and now im doing a turbo set up does anybody know the hp rating on the stage 2 circle d converters
Old Oct 15, 2012 | 06:51 AM
Circle-D's Avatar
The Stage II is rated for about 7-800 HP. But you might have a problem with it being to loose with the new power. Can you fill out an Ask Chris with your new specs and I will let you know what it should do.
Chris
