Is this a 4l80e?
Old Nov 14, 2012 | 09:28 PM
gpr's Avatar
gpr
Default Is this a 4l80e?
I'm not familiar with 4l80e's. bought what i thought was one a while ago and got to looking at it tonight (will be installing soon) and it says hydromatic on the side, so was curious if this is even a 4l80e? Or is it a th400
Also there is a large square **** sticking out on the driver side of the tranny. I'd assume i need to cut this off to install this thing in a f-body? I circled it in red.
Attached Thumbnails Is this a 4l80e?-20121114_192244.jpg   Is this a 4l80e?-20121114_192255.jpg
Old Nov 15, 2012 | 03:29 AM
SnIpEz's Avatar
Yup.
Cut the **** off for more room.
Old Nov 15, 2012 | 08:55 AM
maddoglou454's Avatar
Default 4l80e
It was probably out of a van that **** was for the linkage. Yes it is definitely a 4L80E.
Thank You,
"Mad Dog" Lou
Mad Dog Transmissions
Phone 770-781-0949
Fax 770-781-0969
Web: www.maddogtransmissions.com
Facebook: www.facebook.com/maddogtransmissions
Twitter: www.twitter.com/maddoglou
YouTube: www.youtube.com/maddogtransmissions
Old Nov 15, 2012 | 09:16 AM
01ssreda4's Avatar
Agreed, 80.
Old Nov 15, 2012 | 09:24 AM
gpr's Avatar
gpr
Thank you for the help.
Here is my second question. I was looking at it yesterday and i see the two trans cooler lines which i circled in red in the pic below. Which is the supply line and which is the return? I think I am going to make it run to the stock cooler than out to a plate/fin cooler, then back to the tranny. Also are these fittings a certain thread type?
Secondly, what is the object i circled in yellow? There is a plug in it now, I'm guessing that is where the dip stick goes?
Old Nov 17, 2012 | 02:37 PM
Monte4ever's Avatar
Ttt....
Old Nov 18, 2012 | 07:31 AM
Jays_SSZ28's Avatar
Fluid flows out of the bottom line and goes back into the top line. The thread on the fitting is 5/16" inverted flare (stock it was, looks like those might be later model quik connects.) The plug circled in yellow if the dipstick hole.
