T-56 for 4L60E swap
Old Nov 25, 2012 | 11:22 AM
copteezer496's Avatar
Default T-56 for 4L60E swap
I'm wanting to swap out my 6-speed for an auto with a big stall, but had a couple of questions.
1) The hole where the shifter comes through my floor, will I need to weld a plate there to cover the hole in order to mount the auto shifter? Also, how will I mount the shifter?
2) Is it pretty easy to remove the needed wiring harness for the 4L60E? What all do I need to grab off of the other car?
3) I have the BMR torque arm relocation bracket on it now. Will that work with an automatic or will I need to buy a new one?
4) Is the drive shaft the same length or will I need to use the one off the automatics car? I just have a built drive shaft already and don't really want to spend the money to have another strong one built.
Any advise and tips I could get would be really appreciated!!
Old Nov 25, 2012 | 11:33 AM
got-a-ls1's Avatar
you will need to cover the hole and fab some mounts for the shifter to get the height correct.
the wiring harness is easy if the motor is out of the car, can be done in the car sure but getting all the connectors and grounds off the back of the heads sucks... inside the car wiring isnt too bad but is annoying lol
you will need a 4l60 mount get the bmr.
driveshaft is the same
Old Nov 26, 2012 | 04:29 PM
fastbird02's Avatar
got someone to swap with yet? if not pm me.
