B&M deep pan installed
Old Apr 13, 2004 | 11:40 AM
more carbon's Avatar
Default B&M deep pan installed
nice mod,hangs down same height as hooker LT's so clearance is ok ,pan is a little heavier than stock,recommended mod.
Old Apr 13, 2004 | 12:57 PM
samz28's Avatar
is that the +3qt one? where did you find best price? And what skill level is necessary to safely install this?
Old Apr 13, 2004 | 04:09 PM
very simple to install,you will need a seal for the oil pick-up tube that goes into the trans that they don't supply,and a filter with new oil.got this one from TR with the oil cooler.this will help trans life as both together the oil temp should stay on the cool side on hot summer nights and at the strip.
