Turbo 350 behind an LT1
Old Nov 29, 2012 | 11:30 PM
Bad Chad's Avatar
Default Turbo 350 behind an LT1
I have an RX7 that has an LT1, right now it has a 6 speed in it and I've been wanting to go auto. I already have the turbo 350 and stall, just want to make sure I have everything I need so that I do not have to pull it in and out several times.
Do I have to run a spacer or special flexplate to make it work?
Old Nov 30, 2012 | 04:10 AM
buddhaz06's Avatar
I don't think you do. You can.put a spacer/adapter on the trans to adapt a 4l60 tailshaft to run vss and a shorter driveshaft so u maybe won't have to remake one. You might have to trim the "ears" or brackets on the bellhousing to get it to fit better.
Old Nov 30, 2012 | 11:13 PM
Bad Chad's Avatar
Is the flex plate the same on a LT1 and an LS1?
Old Nov 30, 2012 | 11:25 PM
buddhaz06's Avatar
I'm not sure. Lt1/sbc is same
