4l60e
Old Dec 10, 2012 | 08:57 PM
00silverzzzz's Avatar
Default 4l60e
Put about 2000 miles on a junkyard 4l60e and now it blows the fuse.
Any ideas?
Old Dec 10, 2012 | 09:18 PM
mrvedit's Avatar
Moderator
Any ideas?
The internal harness has cracked wires and they are sometimes touching metal and blowing the fuse. Or one of the solenoids has a short.
You can buy a new internal harness and all solenoids for about $100. Replacing them all requires only dropping the pan and filter, removing two bolts (for the TCC solenoid), a few clips for the other solenoids and popping out the internal connector. To remove the internal connector you need to push down and wiggle a 1-3/16" socket. (I think that is the size.) Or you could just carefully drill it out with a 1/2" wood drill. The new harness will include a new connector and a TCC solenoid. You probably will want to replace the filter and pan gasket too. Some people suggest replacing the fluid; other say not too; I don't have any experience with that.
Old Dec 10, 2012 | 09:34 PM
Thank you.
