4l60e slips in 2nd and 3rd WOT...... whats wrong?
Rebuild held great for about a week.... then began to slip in 2nd and 3rd. So i pulled it out and found the clutches and the band toast.
So i replaced the clutches, drum (warped), and band... just took it out and its doing it again when you run it WOT....
Really lost on this, anyone have any ideas??????
Thanks in advance for any help!
It will hold the gear at WOT for a second.... then all of a sudden let go and act like its in neutral.
I know its not the clutch packs as i just put them in... and they hold fine under part throttle.
Only having the issue at WOT...
Could it be the servo?
For as cheap as they are it will be a good tool to have around!
Ive never had as many issues with the 60e as i am on this one, its one thing after another.....
The only advice i can give to anyone on these transmissions is to do the 4l80e swap if you can afford it. I have swapped and rebuilt many of them and not one has failed yet and they are abused daily.
Has to be either the new converter or the pump.... guessing its the pump hahahaha!
I will post test results tonight!
A 11mm or 7/16" wrench will remove the line port on the driver's side. A racheting box wrench works well.
Remember to keep the long hose off the exhaust system. A couple tie-wraps do the trick.
60ish at idle park
wot in park jumps to 180-210 then immediately drops back to 60ish
if i take force motor with HPtuners and turn it on to 0MA it goes to 185ish at 650ish MA it goes to basically no pressure....
What am i looking at fixing? the pump?
60ish at idle park
However, you say that setting the force motor to 650+ mA drops the pressure below 50psi? I cannot test that myself now, but that sounds wrong; pressure should never go below 50psi. What does HP Tuners show as the mA at idle?
It sounds like your pump is good. If your pressure really does go below 50psi, there is something wrong with the boost valve, pressure regulator valve, the force motor (also called pressure control solenoid) or the AFL valve in the valve body.
The good news is these are all fixable without removing the trans; but I don't know if the current slippage has already damaged the frictions.
TRANS experts: Am I wrong or missing something?
I took the force motor tables in the tune and boosted them a little and everything is working great, no slipping or anything!
i get around 80 psi at idle and around 225-230 WOT!
He will keep driving it till something happens (if anything happens).... I will update again if somethihng else goes wrong!
Do you have a stock boost valve or a larger .500 one?
I don't quite understand how you can get 225 WOT when you got only 185 at 0 mA; I get 225 at WOT and 225 at 0 mA.
But hey, if it is all working now, be happy and don't worry about such tiny details.
And congratulations on successfully rebuilding the trans!
I'll bet you learned a lot in the process and are proud of your accomplishment.
With HPtuners Changing it to 0 MA in the SCANNER it only got 185 when i changed it in the TUNE (about 80% of the values) it got 225-230..... IDK but it worked LOL
Ya ive rebuilt quite a few 4l60e and 4l80e transmissions.... this is the ONLY one ive had a problems with it was a PITA, did get to learned some stuff this time around! And i finally got a trans pressure guage, i will use it on every unit i do now to check things over
3-4 burnup and sunshell have been the problems on the ones i have rebuilt...never tore one down that had any other problems (yet lol)
I rebuilt a 60e i had in my turbo TA about 5 times befor i got the 80E lol
Thanks again for the help and advice!
