trans and gear ratio selection, how important is it?
Old Jan 27, 2013 | 11:28 PM
zayne0's Avatar
Default trans and gear ratio selection, how important is it?
I'm getting geared up for a build of a 92 sierra 4x4 with an ls swap. hoping cash allows for a 6.2, 6l80, and a turbo. Question is how important is choosing gears or a trans with a boosted motor are the gear ratios in some 6l80's different from others? Am I messing up with the 6 speed auto? Does the turbo motor and this trans make a good combo for this build? Any thoughts or comments would be great cause I have never got to play with the 6 speed autos before.
Old Jan 28, 2013 | 08:21 AM
mrvedit's Avatar
Moderator
Personally I am not keen about the 6l80e gear ratios as the 1st gear is a stump pulling 4.02 and then there is a huge drop to 2.36 which tends to knock the engine out of its power range (though less true with a turbo). Then the ratios are very close with two overdrive ratios.
I'm also not confident that a stock 6l80e would handle the power of a turbo on decent boost; not a lot of upgrades are available at this time.
IMHO (and not based on any personal experience) I would suggest a well built 4L80E instead.
Old Jan 28, 2013 | 12:22 PM
Smo's04Gto's Avatar
4.02 to 2.36 WOW thats a huge drop
Old Jan 28, 2013 | 04:12 PM
zayne0's Avatar
Ya just drove a six speed auto 5.3, it awful.
Old Jan 28, 2013 | 04:21 PM
mrvedit's Avatar
Moderator
Glad you had the chance to drive one. That is what I thought went I drove a G8. It would leap to 20mph but then bog down.
Old Jan 28, 2013 | 09:46 PM
zayne0's Avatar
Yeah its a bummer I was expecting it to have ratios similar to a t56.
Old Jan 28, 2013 | 09:58 PM
69cutlassrkt's Avatar
you think gm would have learned from the 4l60e with a 3.059 1st gear to a 1.625 2nd. Maybe the tall first gear of the new 6 speed automatic is suppose to help city mileage or something.
