flex plate ???????
Old Feb 9, 2013 | 12:41 PM
Not Me's Avatar
Default flex plate ???????
I'm confused after reading serval threads I still have no idea where to go. I have a 2006 Sierra 6.0 and I'm trying to made it to a 2000-2001 4l60e. what flexplate do I need are will the Sierra Flex plate work just fine. I hear there a 5.3 dise flex plate mite be it but spacer maybe need it not sure. I'd rather ask a question in the mess anything up I am a newbie. thanks
Old Feb 9, 2013 | 05:18 PM
mrvedit's Avatar
Moderator
Sorry that no one has answered you yet.
I don't know for sure, but thought that all '98 and later V8 flexplates and V8 4L60e would be compatible with any LS-style converter. The complexities come from hooking up pre-98 parts to post-98 parts.
I will be happy to be corrected so that an expert can help out here.
Old Feb 10, 2013 | 01:29 AM
Not Me's Avatar
thanks but I need to be sure. come in guys little help please
Old Feb 10, 2013 | 07:43 AM
Circle-D's Avatar
What converter are you using? What transmission did the 2006 6.0 come with?
Chris
Old Feb 10, 2013 | 09:26 AM
Not Me's Avatar
I got motor without a tranny. I bought my tranny from a friend out his car. now here's the trick part when he got the tranny it did have a torque converter. so got that used so not sure there. but to run it in his car he got a special flexplate I think. but he has a 2000 6.0
Old Feb 10, 2013 | 01:25 PM
mrvedit's Avatar
Moderator
Chris knows 1000x times about about this than I do and I'm glad he is trying to help you out.
However, you are looking for a "sure" answer to the fit of unknown parts.
Chris can probably help you more if you post some pictures and measurements.
Put the converter down on it tabs and measure the distance to its top; this will ensure it isLS compatible.
Measure the distance between various bolt holes and describe which bolt holes these are in the picture. Some flexplates
Old Feb 10, 2013 | 02:22 PM
Circle-D's Avatar
Yes, please post some pictures. No measurements needed.... Just a pic of transmission, flexplate and converter.
Chris
Old Feb 10, 2013 | 05:55 PM
mrvedit's Avatar
Moderator
WANTED - Woman with good transmission.
Send picture of transmission, flexplate and converter.
Sorry, couldn't resist.
 Michael S. Palmer
Old Feb 10, 2013 | 08:58 PM
Circle-D's Avatar
Thanks for the laugh, that was funny.
Chris
Old Feb 13, 2013 | 12:21 PM
Not Me's Avatar
ok im working on posting pics. but from what I see the bolt holes on the torque dont line up with flex plate
Old Feb 14, 2013 | 03:13 PM
Not Me's Avatar
See the bolt hole don't line up
Old Feb 14, 2013 | 03:19 PM
Not Me's Avatar
here pics lil help please this is the biggest thing holding me up on my swap
Old Feb 14, 2013 | 03:24 PM
Not Me's Avatar
is the the right converter
Circle-D's Avatar
That is a 4L80 style flexplate. You need to get the dished 4L60 type. It will have the right bolt pattern and you will not need the spacer. We have a SFI version if you can not find one.
http://www.circledspecialties.com/p-...flexplate.aspx
Chris
Old Feb 14, 2013 | 03:30 PM
Not Me's Avatar
As I'm on a thin budget would this work as well. An will I need a spacer.http://www.summitracing.com/parts/bmm-20340
Old Feb 14, 2013 | 04:10 PM
Circle-D's Avatar
Don't think so....Not sure what bolt patterns it has. I think that is the same you have now. Look for a used one off a LS truck with a 4L60E.
Chris
Old Feb 14, 2013 | 05:59 PM
jrpimp00's Avatar
I used my stock 98 flex plate to attacj my trans to the 2004 LQ4 if that helps, as stated above its the dished kind
Old Feb 15, 2013 | 05:45 PM
Not Me's Avatar
Thanks guys. I also called gm tech an they said the same thing to use the 98-02 ls1 flex plate.
