200-4r to LS1 mounting bolts
Old Apr 18, 2004 | 04:05 PM
93LS1RX7's Avatar
Default 200-4r to LS1 mounting bolts
I only have 5 bolts holding the bellhousing to the engine. Is that all that I should? Is that enough? The other holes dont appear to line up to anything so I think I am good to go.
Old Apr 18, 2004 | 04:11 PM
Dragaholic's Avatar
9 Second Club NA
If youre bolting the tranny directly to the engine, then only 5 will go. Plenty of guys running it that way with no problem at all. Thats the way I have it done. Dont worry, its plenty.
Old Apr 19, 2004 | 11:01 AM
john kilgore's Avatar
Default bolts
if you had a 1975 chevy monza with a v-8 it only had 5 bolts from the factory, so don't worry. your car must be an animal to drive. jk
Old Apr 19, 2004 | 11:23 AM
93LS1RX7's Avatar
It was before the nitrous and tranny swap. I will tell you once my driveshaft comes back if it is even better!!!
