on my 2nd 4l80 and having the same issues as the first
Old Feb 13, 2013 | 09:31 PM
zerofx150's Avatar
Default on my 2nd 4l80 and having the same issues as the first
I have a 2000 TA and i did a t56 to 4l80 swap with a yank converter. when on the hiway approaching 70mph my tranny unlocks and then acts like its in neutral and searching for a gear. this happens at the 2500-2800 rpm mark. im using both vss sensors with efi live cos5.
car has:
yank ss 3600
410
cammed ls1
being the second tranny and still having issues in curious as to if its in the tune and what perimeters i need to look at and maybe a sensor as well. the car shifts through all the gears and locks up as well. this is the only issue i get but i dont get any codes.
any help would be appreicatied!!
Old Feb 14, 2013 | 12:08 AM
Jake's Performance's Avatar
Sounds like its returning to 2nd or 1st. Are you sure you are running a 4L80 segment?
Command each gear as you accelerate and see if it works.
Old Feb 15, 2013 | 09:15 PM
zerofx150's Avatar
Ill give that a shot. I just gotta get time to get it to my tuner. I hope this is something simple.
Old Mar 8, 2013 | 06:18 PM
zerofx150's Avatar
well we discovered the seg swap corrupted upon install and thats what did the first tranny in(plus it had a million miles). Got a good solid tune and a fresh tranny in it and its amazing. gotta get a few things with the shift points fine tuned and this thing should be good to go!!!
Old Mar 9, 2013 | 09:37 AM
rooster99ss's Avatar
A ha....mine's doing something similar to that. Sometimes too, it seems when I shift it out of park it has no gears. Put it back in park (sometimes it takes a couple of times), and then shift down and it has gears all of a sudden. Strange. We just put this thing in, still working out the bugs on it
Old Mar 9, 2013 | 10:42 AM
I8UR4RD's Avatar
I grabbed the 60e-80e harness which requires no segment. Controls the 80e with the 60e segment. Plugs and plays.
