Stripped converter hole
Old Feb 15, 2013 | 11:50 AM
ls1jorge's Avatar
Default Stripped converter hole
Has anyone ever had a problem with a stripped converter hole? If so what did you do to fix it? or what can i do? Im debating to buy this 4000 vigilante.
Old Feb 15, 2013 | 01:08 PM
mantycarguy's Avatar
Is this made of aluminum or steel? If aluminum take it to a machine shop and have them tig weld it up and rethread or helicoil it if they can. If steel a helicoil should work just fine.
Old Feb 15, 2013 | 01:18 PM
ls1jorge's Avatar
Its steel, Can the machine shop still fix it if they use Helicoil?
Old Feb 15, 2013 | 01:44 PM
ss performance's Avatar
There is a system called "Lock n Stitch". I have seen it used to replace head bolts in cracked blocks. You would need to find a machine shop that can do it. Check out thier site.
http://www.locknstitch.com/
Good luck.
Craig
Old Feb 15, 2013 | 01:59 PM
ls1jorge's Avatar
Thumbs up
Thanks for the feedback fellas I apperciate your help, I found a local machine shop "Serive Parts & Machine" in San Antonio that can do it.
