What converter should I go with?
Old Feb 26, 2013 | 02:54 PM
bignasty's Avatar
Default What converter should I go with?
So I know there is alot of good converters out there to go with on the 4l60e,
Im just not sure which way to go, thought I would ask for some opinions here.
I have a 2000 SS camaro, makes 420ish on the wheels, spraying the car 125 shot and the converter is just not wanting to take it, it surges on top end as well, planning on upping shot to a 200 shot, 3.73 gear, planning on riding the car on street some just around town and what not but no big trips or lots of miles or anything. More track use. So what is your alls opinion?
Old Feb 26, 2013 | 03:09 PM
SMOKNSS's Avatar
I run PTC converters. My car used to have a H/C/I LS1, th400, 4.10s, 28" drag radials with a 200 shot. It was even my daily driver for a short time. I never had any issues and car always performed well.
They will be building my converter for the turbo build this year.
Old Feb 26, 2013 | 03:43 PM
bignasty's Avatar
You say PTC, now is that the same group that does the vigilante converter?
Im just wondering do I really need to go with the triple disc converter or will the single disc be good enough for the job, Im figuring 650hp as a goal.
Old Feb 26, 2013 | 04:29 PM
justin hover's Avatar
Yank...ptc...fuddle.....remax...Look at some sponsers----->...I wouldn't get anything under a 3600....4000 dd here..
Old Feb 26, 2013 | 04:38 PM
Chaos07's Avatar
i have a revmax 3600, THAT with a FAST 92 will put u in your seat lol
Old Feb 26, 2013 | 05:41 PM
sabersaw30's Avatar
http://fticonverters.com/
Call Greg he will set u up.
Old Feb 26, 2013 | 06:02 PM
Z28SteveA4's Avatar
i would look at the Pro Yanks series converters. they are designed for big no2 shots. Even the Yanks SS4000 would like a 200 shot and slam you into your seat.
Old Feb 27, 2013 | 10:24 AM
bignasty's Avatar
So will revmax and pti, and yank and all of these converters lock up at wot or would that
even be an issue for some of you? I do plan on riding the car some on street but not alot,
just locally here ya know.
Old Feb 27, 2013 | 11:12 AM
Circle-D's Avatar
For WOT lock up you need a billet multi disk, our multi will handle the 200 shot no problem. I can help spec you a converter, just need you to fill out an Ask Chris form with your full info. Link is in sig...
Thanks,
Chris
Old Feb 27, 2013 | 11:29 AM
bignasty's Avatar
Thanks,
Chris
Thanks Chris, just sent it to you.
Old Mar 1, 2013 | 08:15 AM
bignasty's Avatar
Ok Ive narrowed my choices down to a couple here, and just wondering the pros and cons with some of you guys running a single disc compared to a multi disc. Some say the single disc will make quicker track times, any thoughts?
Old Mar 1, 2013 | 08:42 AM
TXZ28LS1's Avatar
Circle D!!!
That quality of that damn converter is beyond impressive!
