I bought a transbrake button,....now what?
That's the only way to learn when you have no help lol
I have the new style TransBrake/ D3 so I can launch in basically any gear although I will be leaving it in 3rd.
I went to radio shack looking for a double pull double throw switch that way I could use the same button for the line lock then switch it over to the Trans brake but there selection was rather thin. I found some neat lightup switches though that would fit.
I think I will just run two separate switches. I do not want to do a drop stick because I get nervous it would drop on the button somehow. I have never seen what happens when someone hits the trans brake while moving but I can imagine its not good. I ordered this one so far. May switch if anyone has better suggestions.
